sonicmook56
Hey all, I know there are some Lexicon experts that frequent this form so, if that's you and your reading this, I have a few simple questions.
First off, I generally don't work on this type of gear at all so please excuse my ignorance.
What I have here is a Lexicon 224 reverb that sounds very distorted. All the power supply voltages are healthy and look good on a scope. Upon power up I get error message "E91" on the remote's display. I referenced the service manual and learned that this error is a "memory error". ok, easy enough. I found replacement RAM chips from an online vendor and went ahead and started swapping out each chip for a new one and listing to the output. Eventually all chips were completely swapped out and output distortion did not change. One weird thing about the "E91" error is that the owner said that came on every time and it worked great, so this error might just be a glitch?
Digging into the service manual a bit more I found you can force the unit into self test mode by removing cards DMEM, T&C and ARU from there sockets. Powering up the unit in this mode allows the audio to pass, and it's STILL very distorted. This is where I'm stuck. I'm not sure what I need to troubleshoot next. I don't have any extender boards so I can't see getting a 'scope probe on the A/D and D/A boards to look around.
The only cards in the mainframe are the SBC, FPC and the Ain and Aout cards, so the fault must be on one of these. I might try replacing the caps on the FPC board.
The P.S. decoupling caps on all the cards are tantalums. Is it safe to replace these with an equivalent electrolytic?
Thanks for reading this.
