i have bought a Lexicon PCM 70 as non working with the intention of repairing it, or at least wasting some time trying to understand obsolete 8 bit digital circuits...
i have managed to get the analog path working. all the power supply rails are fine.
the main problem is in the digital circuit. the processor is basically not turning on properly and when the unit is powered on the display is not lighting up
after reading the very useful troubleshooting procedure in the service manual i have scoped out the master processor section and found out there is problem with data line 7 (pin13 on the z80 cpu) which is not displaying data and is stuck high.
the remaining data lines and all the address line are showing some data on the scope so it seems the processor section is at least partially working
i have tried removing ROM, RAM and ADC chips to see if they were keeping the data line 7 high , but they don't.
The rest of the i.c. are not socketed. I have removed a couple of the logic chips that are on the data lines and I am waiting to put fresh ones in and see if it makes a difference.
There are more i.c. that I could try swapping out but it's kind of a shot in the dark
Just thought I might ask some help here and see if there is someone around that knows these kind of units
