Potato Cakes
Hello, Everyone,
I have been trying to build a four segmented LED VU meter but I am a little bit stuck. I am working off of the attached schematic from a console service manual. The differences are I am using 1N4148s, a BC560, a TL072, an LM339, and a +V/0V power supply. I have seen TL072 used with single source power supplies but I do not know if that can be done in this configuration. I may have to use a virtual ground scheme.
In my test build, all of the V- connections from the schematic are connected to 0V/GND. When I wired everything up, all of the LEDs lit up, so I started taking things apart to do some individual tests. The first problem I an running into is the TL072 buffer/rectifier circuit. It is my understanding that the first amp is the buffer and the second is a gain stage where the AC is rectified by the 1N4148 (BAS16 on the schematic) which is then fed to the LM339. However with no signal, the DC on where the 1n4148 and 1k8 resistor meet is equal to the power supply. When I apply signal to the input, I get less than a 1V of change, even at +18dBu and the input. So I guess the first thing I need to make sure I get is that change in AC voltage to the op amp should show a change in DC on the other end of the diode or am I missing something?
Paul
Paul
