Bo Deadly
Does anyone see an issue with using a 10 ft usb-c cable between a 2018 mac mini i7:
Mac mini (2018) - Technical Specifications
and a MOTU UltraLite mk5:
Specs | MOTU.com
In this particular scenario the mk5 is only usb-c 2.0 which is limited to 480Mbps so I'm thinking a 20Gbps cable should be able to handle the longer cables without problems. Am I ASSuming too much?
Here are some examples of 10 ft cables I'm looking at:
https://www.amazon.com/USB-Cable-3-1-USB-C-10ft/dp/B089FV33QX/ref=sr_1_2?crid=3TBXR8POJDIE6https://www.amazon.com/UseBean-Tran...t/dp/B0BN5M5R8Z/ref=sr_1_10?crid=3TBXR8POJDIEhttps://www.amazon.com/Twozoh-Trans...3/dp/B0BG83RX1Z/ref=sr_1_14?crid=3TBXR8POJDIE
There are also some 15 ft cables that claim to do 10Gbps.
What are your good / bad experiences using long USB cables with audio interfaces like this?
Any drop-outs / lost connections?
Specs | MOTU.com
