Can anyone give me info on this transformer.
Isn´t it a 10468-like transformer? I think so...
Hi Rob,
No they are not equivelant, the T1447 have higher ratio and higher impedance on the secondary (more gain)
The T1447 primary can be configurated for 1 kohm in serial or 250 ohm in parallel and secondary 8 kohm in serial or 2 kohm in parallel.
And the orginal Neve microphone input 10468/VT2240/T1454 primary 1,2 kohm in serial or 300 ohm in parallel and secondary 4,8 kohm in serial or 1,2 kohm in parallel.
--Bo
Marinair T1452 = Neve 31267 line input. 2+2:2+2 - ??IIRC
I think from memory you just wire it up like you would a 31267 for mic use. It just gives you a bit more gain because the ratio is slightly different.@Rob Flinn I know it's been a while, but could you share some details of your wiring of the T1447 for mic levels?
Thanks a lot, I will try it out. Getting more gain is actually a nice perk! Did you compare the sound to a 10468?I think from memory you just wire it up like you would a 31267 for mic use. It just gives you a bit more gain because the ratio is slightly different.
