Looking for some specs on an isolation transformer
Help Support GroupDIY:
CurtZHP
Allentown, PA
We've got this North Hills Electronics 1116PA isolation transformer. It's used mainly for television signals. I'm trying to find some specs on it, but Google has been no help at all.
Any of you folks ever come across one of these? We're mainly interested in what sort of voltage differential it will handle. Suitable for lightning protection?
(We've got it on a cable run between two racks located in two separate buildings. I guess the thinking is if one building gets hit, there's no direct copper path to the rack in the other building.)
Nothing to do with DIY audio, but I figured I'd ask.
emrr
NC, USA
I think I’ve seen one once, would expect similar/less than the ADC HUM-1, probably 500v or 1000v , certainly not multi kV.
CurtZHP
Allentown, PA
I kind of thought so. I told my colleagues that I figured, best case scenario, it ends up acting like a really expensive fuse!
abbey road d enfer
Moderator
Marcelland
No. It is used to isolate galvanically two distant circuits, where longitudinal noise could be very significant. The isolation voltage is probably around 500V, no more.
Protection against lightning involves very different techniques.
CurtZHP
Allentown, PA
Fortunately, the other engineer informed me that the gear on one end of the cable will be moving into the same room as the gear on the other end some time in the coming months, rendering the whole thing moot. Hopefully, it happens before summer thunderstorms get rolling.
