rascalseven
Lots of knobs for sale that need good homes. Thanks for looking.
Round, plastic knobs (look like bakelite, but not sure). 1.48" diameter. White line. 1/4" shaft with set screw. Four total. $5 each.
[/url]
Neve NAD dual-concentric knobs, original, taken from 31102 channel modules. Blue caps are stained with age, but are original. Proper replacement caps are available on ebay pretty often. Seven dual-concentric pairs are available (5 medium blue (EQ section) and 2 light blue (HPF/LPF)). A sixth bottom knob (of a dual-concentric pair) is also available. $15 per dual-concentric pair, $7 for orphan bottom knob.
Medium blue sets:
Light blue sets:
Underside:
Orphan bottom knob:
Pushbutton caps for Neve 31102 module (also used on other NAD series Neve modules). Two sets, original. $5 per set.
Black, plastic, fluted knobs. 0.935" diameter. 1/4" shaft, brass insert with set screw. Fifteen total. $2 each.
dbx Project 1 colored Sifam, push on knobs. Taken from various dbx Project 1 units. Good shaft. D-shaft push-on. Rubber texture. A bunch available. $10 for all.
New Sifam/Selco DRN110-006BLACK knobs with grey caps. 0.56" diameter. D-shaft, push-on. 58 total. Bought these new for a project that never happened. $15 for all with the caps.
Black knobs with spun aluminum caps. Black pointer line. Sturdy knobs. 0.53" diameter. 1/8" shaft. Heavy brass bushing with set screw. 22 total. $2 each.
Pultec filter select-style knobs. One pair. 1.5"x0.755". 1/4" shaft with set screw. $5 each.
Generic black plastic knobs. 0.8" diameter. 1/4" shaft. Brass insert with set screw. $1 each.
Military style black knobs with aluminum caps. One pair, different diameters (can be used for one channel mic preamp, gain/trim). Diameters 0.93" and 0.71". 1/4" shaft. Brass inserts with set screw.
More military style knobs (one pair, different, though similar to above). 0.72" diamter (both). 1/4" shaft, brass insert with set screw. $2 each.
https://flic.kr/p/DFzDaH
Medium blue sets:
Light blue sets:
Underside:
Orphan bottom knob:
