First of all, this is my first attempt in DIY mic preamp so if I ask too much newbe questions in this thread just tell me and I can send PM instead.
From the pics of a 4 channels build on your site, I see that 5 horizontal channels would fit. So I'll design the front panel to accept 20 horizontal modules in a 4U.
I'd like to make a hybrid version (since it's possible), with a M-1 front end and a 312 back end.
I'd like to put the Lundahl 1538 at the input, the Hardy 990C+ and the Ed Anderson 2503 output transformer.
A quick question about the Lundahl 1538 vs 1538XL:
1. Both SPL and Focusrite use the XL version in their design, is there a benefit in using the XL instead?
ok next
I'd like the stepped input gain to drive the Lundahl/990 and the variable trim pot to feed the 2503.
So:
2. Would it work? Is the TRIM pot before the output transformer? Sorry if the answer is obvious...
And:
3. Does the trim pot act as an attenuation only or does it act like a "fader" to push the out level +6db or so?
Last:
4. To implement those parts (Lundahl 1538 (XL?), Hardy 990C+, EA 2503), could I built the 312 and simply swap the input xformer and opamp or the circuit parts must adapted to accept those two "non-312" parts?
On a side note, the DIY JE-990 provided by Hairball audio look like a very nice alternative to the Hardy's own 990C+ for half the price.
Any experience with this one?
This price difference will truly matter when multiplied 20 times...
ok next
So:
And:
Last:
