stokesmusic
Member
I have a pair of M-Audio M3-8 speakers laying around, and one morning when I turned them on, the left speaker started making a saw-tooth-ish 150 Hz noise, which I'll attach to this post. Predictably, M-Audio was of no help, and the cost of repair exceeds the value of the speakers. I also wasn't able to find a schematic for them, which complicates trying to trace down the problem.
I checked the boards for burnt resistors or bad solder joints, and didn't find any obvious issues. The sound occurs without any inputs connected, just power. I checked the speaker with multiple power outlets, and power cables, and all had the same result.
Thank you in advance for any advice you all might have!
Colin
View attachment M3-8 Speaker Noise.wav
Colin
