I'm servicing a MACKIE PPM 808M that channel 1 doesn't work but channel 2 is just fine. I've determined the input op amp (U3A - NJM4560M), is bad. This is the input op to the power amp board from the mixer board. Of course the part is obsolete. Anyone have any recommendation on which of the following similar parts I should use as a replacement?
NJM4565M
NJM4580M
TLC272BCPS
Also, how important would it be to replace the good NJM4560M input op amp on channel #2 with the same new op amp part number that I'm using in channel #1?
NJM4565M
NJM4580M
TLC272BCPS
