Magnasync/Moviola
psychedelnick
Member
LAX/PDX/SEA/YVR/West Coast
Hello out there, I have a bunch of magnasync moviola modules/(pre-line amps?) from a record and reproduce of a large editing machine. Does anyone have any info about these?  Most of them, about 40, look like the one pictured. They are housed in a rack, kind of 500 style.  A few others look a bit different, some have  large RCA transistors(!) and seem to be part of a buss section?
Right, so if anyone wants to hook a dude up with some info that'd be great. OR if you live in the LA area and want to help me get them up and running (if it's worth it) I would give you a couple to have. More pics on request. Thanks-
    389.9 KB
I have some of their stuff. A tape repro head amp thing that runs on negative 24 volts to germaim transistors. It uses pull outcards kind of liek yours....they are an old film company, the units i have came from a machine that plays the audio on film. old stuff.
Anyway I wired one up as a microphone preamp....and then turned it into an optical compressor and then trashed it...Still have the cards and everything. I couldn't find ANYTHING online though...
Goodluck!
AH! It does not tell you when you get a reply! Thanks for the response. Oh well I can still salvage a few parts from them. I found a few with some germanium transistors labeled 2N301 424 which I'm sure I can get some use out of? Fuzz box? Awyway thanks for the feedback!
I think so, I'm new to all this. There are 2 pots for bias on the front and one for gain. They're housed in a 10 card rack labeled record /reproduce amps. I would show you some other pics but I'm away from home for a long while. I see you are Dutch, my last name is deWitt...
Hit the notify button next to the reply button at the top of the thread and you will receive emails about replies.
-Casey
