Maihak w66c Fader pinout?
mkiijam
I need the pinout for these faders. I have found this online but the measurements I'm getting off the actual fader don't seem to jive and/or there is more going on in there.
Pin 1 = IN HOT
Pin 2 = IN COLD
Pin 3
Pin 4
Pin 5
Pin 6 = GND
Pin 7 = OUT HOT
Pin 8 = OUT COLD
Pin 1 = IN HOT
Pin 2 = IN COLD
Pin 3
Pin 4
Pin 5
Pin 6 = GND
Pin 7 = OUT HOT
Pin 8 = OUT COLD
That pinning is correct as far as W66 goes. What measurements are you getting? I don`t know if W66C is much different.
There appears to be a switch that's engaged when the faders is all the way down.
That should not be difficult to trace ?
-com/no/nc with the 3 left connector pin in case of fader start/signaling
-or a kill switch that connect wiper to gnd
yes, that part will be easy. Heck the whole thing will be easy, just thought maybe somebody had it as it always (almost) nice to have the factory info. The addition of the switch made me think that there is another version or document out there that has all that regular info in it.
