Making a stereo mic
I have capsules and a circuit i would love to make into a stereo mic with rotatable top mic to do different stereo tricks. but i haven't been able to find a mic body that can hold two capsules except to use a 500 donor mic which is too expensive
This might be a good starting point.
Not really cheap, but it saves you a lot of difficult construction problems:
http://www.recording-tools.com/product_info.php?info=p26_mcs-02-stereo-mikrofon.html
Stack two head cages, not connected. In the top of the lower one, put a 1/8" TRS jack. In the bottom of the upper one put a 1/8" TRS plug. Figure how much circuitry needs to be in the top cage to get the signal through the 3 conductors. You have infinite rotation for about 3 bucks.
If it has to "look Pro", that 300 buck product Rudd linked looks like a tremendous bargain, and you won't do better either pre-made or with your own valuable time.
