Sold Mammoth Cave Audio Passive Stereo Switcher
IndietownRecording
Really cool piece from Mammoth Cave Audio. It's a passive stereo switcher. Select between two input sources (plus an aux input) and select between three stereo outputs, plus sub/aux output. Also has a switch for mono, sub/aux output and mute. All TRS connections.
I listed as non-functioning basically to cover myself here. I had this hooked up years ago, and remember the output (or input) being wired out of phase. And maybe the aux input having a grounding buzz? I can't remember.
The good news is that this is all straight wire. The fix is as easy as swapping the wires on the outs. If you like to tinker, this piece is for you. $80 shipped.
