Rob Flinn said:If it worries you a lot, you should check whether it is 1dB at all freqencies & similar boost/cut levels on didderent frequency settings. If it is then it's in the amp & you should be able to sort it out.
If it's not then it will be a cumulative effect of component tolerance in the filter section. Bear in mind pots have something like a 20% tolerance . If you used CC resistors they will be 5% tolerance. The caps will be something like 10%. So if it is to do with the filter section you may struggle to match them.
hugo said:Hi Rob, thanks for answer.
I actually measured every single component to have a perfect matched pair..that is why i dont know how to find the origin of the difference
yes i get it but 2db difference between 2 channels could probably kill a good stereo mixCJ said:designed in the 50's for crude telephone eq, not meant for 1%,
