amazingalf
Member
- Joined
- May 10, 2020
- Messages
- 9
I've been building a MEQ5 using the analogvibes chassis and wiring diagram and I'm having difficulty getting the 3PDT 'In' toggle to work correctly. The unit also exhibits a few other behaviors that seem incorrect. I've attached the wiring diagram for reference. I'm hoping that someone will be able to point me in the correct direction based on the following:
- All controls on the unit function regardless of whether or not the 'In' toggle is set to 'In' or 'Out'. There is no difference sonically or functionally between the two positions. The unit sounds good aside from some audible hum.
- My understanding is that this switch should toggle between filtered and unfiltered. Is this correct?
- What is wrong with my wiring or the schematic? How do I get this switch to function properly.
- It seems like the unit is louder than it should be by about 6db. I needed to adjust the send signal on my DAW by -6db in order to prevent the unit from clipping.
