thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
I've had a Sowter 9045 for a while and have decided to make a single channel mic pre from a pair of DOAs. Please see attached drawing. The idea is to get around 35dB max. gain from the i/p stage. My questions are:
The 9045 can be switched between series / parallel primary for ribbon / condenser mode. Do you think I should use the spare pole on the switch to change the gain network, or will the feedback values / 470R pot give enough range?
Can you see any areas where the design could be more elegant?
Many thanks in advance.
Justin
Justin
