ruffrecords said:Many of the passive EQs I have designed have a mid boost/cut section and it would not be too hard to build one with only this section if you wanted. All passive EQs with boost do require a gain make up amplifier of some sort.
wizard60 said:Thanks again Ian!
... just to start to experiment... do you have a simple LC calculator to suggest to me? I need to check differents impedance scenario
Marco
wizard60 said:Hi again Ian,
hope to not bother you... something is missing in my brain... Rcut and Rfix, how I must consider them?
Thank!
Marco
wizard60 said:Thank you again Ian... now all it's more clear to me. One more question please:
When the RCL mids are setted in boost, the variable partition is made by the pot and by VR2 (Hi-cut shelf). When we're in cut position, supposed that we dial the mids for max attenuation, the partion is made by Rfix and Rcut, but is VR2 in parallel to Rcut?
Sorry for may bad English...
Marco
