actually, u dont even need to use additional gang... you are not gonna store your movement of your pots over a period of time... u only need to store fixed position of pots. so
u can use the same pot.
once u ready to store your settings, just disconnect the pots from the circuit, and
feed some DCV( 3-5vdc). and store that value to micro... when u want to recall, do the same...
you only need to read one gang...
"disconnect the pots from the EQ circuit," : i am not an electronic expert, but you would need relays and some fixed value resistor to keep eq safe, ... it may damage your board... experts will explain better...
on some old SSL recall boards, when u do recall, u run a recall software and, you dont really run audio through...
u switch to audio, after your setting done...
only drawback, when u need to store your your setting, ( which is press of a button) no audio should be active... but who cares...
that solves your getting custom pot problem on 3 gangs... but a lot of relays...
ps: you would need additional gang, if you are doing flying faders... as u need to record pot value over period of time....
pps: for 3-5 VDC. as i am not expert in audio electronics... u may need to use smaller value, 3-5 vdc might be too much for pots life ???... experts will tell you better on that value...
ppps: when u ready to store, u may not even need to bypass the pots... just bypassing audio could work too...
not sure, if feeding small DCV would damage any circuit in this case... experts
