TilburyMusic
Member
Howdy,
I'm in a bit of a pickle with my modded MK1 LA-610 and my tube guy pointed me toward this forum to see if I could find anyone to help me with it.
The preamp was modded by a company called CC&E a few years ago, but the company no longer exists. So obviously I can't send it to UA for repair, due to the mod, but I'm having a hard time finding anyone else to look at it and hopefully fix it.
I'm not sure if it's an issue with the modded components or something just went out and needs to be replaced. I actually never used it after the mod, aside from some quick tests during which things seemed to be fine, as I ended up having to pack up my gear shortly after and wasn't able to set it back up at a different location for a while. When I began working with it, I noticed the issues: There seem to be some gain problems (output too quiet), distortion where it shouldn't be, some of the pathways from the mod aren't working (you can bypass the EQ or Preamp and rearrange the order), and when I open the unit up after it's been running, there's an unusual smell of burning electronics or something. But it still turns on and passes audio through, sounds like it could be really great if it were working properly. Something may have just gotten damaged in transit, it may be something super simple, I'm really not sure.
I have a list of all the modifications made, if that would help any.
If this is something you think you could work with me on resolving, please let me know and how much you would charge.
Also, I'm in Colorado.
