Hey all, I tried to do some maths to calculate EF86 B+ load resistor to test/design a modded power supply with out endangering my tube. What is the proper way to figure this out? I just did some ohms law with R = 210v / 0.1A . Giving me max 21k. Is this correct?
I'm going to mod this Alctron psu for my u67 and want to know what the load would be on B+.
I just RE'd the circuit they are using and will fill in the values I need with the correct resistors.... maybe add more filtering if necessary. Potentially also make the H+ side non regulated?? Basically was trying to mod this like Chunger does for MK67 build thread but my pcb ended up being a different model... so I have to figure it out on my own. (which at first was a drag but now am enjoying the learning process.) I did get enough of the mod to remove the diodes in D5 and D6 position and add a bleeder to ground.
Here is the schematic i came up with from tracing the PCB.
I think I can take out the LM317 from the situation and use the resistor rails as a voltage divider to get from the 20vdc down to the 6.3vdc that I need for the tube (6.15v ideally).
Now I just need to know the B+ load for ef86 and I can hopefully calculate the correct resistors. This is my first time building/modding a PSU from scratch... so this is exciting.
I already built my DNU67 so modifying this is more of a research project to see if the "better" power supply really makes a difference for audio quality.
Any advice for improvements?
Thanks!!!
Thanks!!!
