camarada78
Anyone experieced with Mooer Ocean Machine pedal? It is pretty sophisticated and mine have some issues.
First i got full bypass sound, but after some "work" it is fully without sound (lol). Still turns on and all controls seems fine.
What i had:
- Regulator WRA1209 giving the correct voltage (+9v, -9v). which seems correct
- 117 regulator receiving +9v, it was delivery 8.5v. Seems wrong cause the adjust resistor are 1.3k and 475 (should be 4.7v)
- burning hot CS4272 converter receiving 3.2v on Digital Voltage IN and 8.5v Analog Voltage IN. Changed.
- no obvious caps or resistor burned. Only a Cap on the 117 regulator circuit around 25% wrong value, changed.
After changing the 117 twice, I got 5.3v on output (the first one was 6.6v weirdly); The resistors values (1.3k and 475ohms) "should" make a 4.7v output, and the resistors are fine. But 5.3v its not that far from theoretical 4.7v.
The datasheet for the CS4272 says Digital Voltage In should be 3.3 to 5v but the Analog Voltage In should be the same value as Digital Voltage IN +0.3V, so one of them is wrong.
Since i dont have a schematic i dont know if the Digital Voltage IN should be around 5v or the Analog voltage should be 3.3v.
Any clues?
What i had:
Any clues?
