Motor transistors keep dying on me
Have you double checked that there is no connection between the transformer windings that supply the two motors? Your symptoms sound like exactly that fault. Those windings need to be completely separate. If one transistor hangs in there fine, it points to a wrong connection between supplies.
What kind of insulator mounting kit are you using?
I've tried a few different ones. I don't know what they are called in English but it's "glimmerskiva" in Swedish, which seems to be the standard. Haven't had issues with them before.
Are you ready to kill somebody yet?
Yes, myself! This is really taking a toll on my self-esteem as a repair guy. I usually manage to fix stuff
Don't worry, the more pain, the more joy.
Thanks, I will try to keep this in mind.
I'm writing a thesis all week so might not be able to do anything with the machine until Friday. But maybe we'll have time to make some fault hunting plans during the week. I'm very grateful for everyone chiming in.
Update: so today, between writing on Althusser and drinking copious amounts of coffee, I fault searched the logic for the take up motor. Turns out it was just a faulty opamp. I'm thinking, maybe this opamp going rouge could be the reason for the transistors blowing? Will order a bunch of transistors and also check the windings like Radardoug told me to do. Right now there are some TO-3's on sale in my regular shop for only 0,4 euro a piece but they're rated 160v and with the nominal voltage in the machine at 150v I think I'm safer getting some badass deflection transistors for expensive prices again...
Faulty logic driving power transistors can tell them to both turn on at the same time often with bad results.
This was a known problem with early class D audio power amps, where they would shut down whenever they detected low power supply voltage to prevent stupid logic states.
I hope this is the root of the issue.
One thing that is nice with these machines (as opposed to the piece of **** fostex G16 I cut my teeth on) is that there is no obsolete microchips in them, making them repairable, even if the problems are hard to pin down in such a complex system. If anything ever goes bad in the system control unit I think I'll just swap all the logic chips en masse as they're all socketed
Ok, so here's s strange thing: the opamp and the logic chip breaks when I have the transistors installed and press rewind/ffwd. But they seem to only break when the transistors are connected. Something tells me there is some sort of issue with the ground. What do you guys think?
Checked the reel control board now. D11 and D14 had stared conduction on reverse. Let's see if I can find some more utterly confusing stuff.
The reverse voltage hypothesis could work with the fact that it is usually the base-emitter junction failing. Maybe I should try to put a powerful diode on the base or emitter and see if that makes a difference? In that case I'd be closer to thee root cause
Can you run the motors directly off 100V AC , no transistors?
Measure current. Check isolation windings to ground, should be meg ohms.
You can use the AC voltmeter to motor case with one wire of motor hooked up to 100V AC.
Voltage / 10 meg = your leakage current.
Thanks for the advice. I wanted to do this but I'd have to remove the connector for the motor and cut wires so I will try to exhaust every other option first. I've run one motor all night and that seems to work. Need to get yet another transistor...
On the motor running properly I've now added a diode in series with the base and a diode in series with the emitter. I'm not sure if that helped.
I know a guy over in the US who might have the reel control card, and I think I will get that as more and more points to that card being the issue and I just don't want to mess with this **** anymore.
