Mounting PCB's
Hayman
How do you mount your boards inside the chassis?
I can see that there are a few different spacers and stuff that one can buy. I was just wondering what you guys prefer?
Richard
M3 screws and 6mm 8mm or 10mm brass based stand-offs
... contersunk on the bottom plate
A staple part of my diet from Farnell and Jaycar.
[quote author="dripelectronics"]my favorite are the 20mm tall metal standoffs from radio shack.
:cool:[/quote]
I'm with you there. The Shack also has some good heatsinks, LED's and LED holders.
These are my favourites:
No enlarging of holes cos' you're 1/2 a mm out in the drilling..... :mad:
RS have them, 220-771, 609-281 are the RS numbers.
Peter
[quote author="peterc"]I have had some in my projects for 10 years & they are still good.[/quote]
:grin: That's good, you'd imagine the sticky stuff went bad in 10 years but apparently not. Thanks!
Do they stick well to the chassis and hold there?
Like **** to a wool blanket :grin:
Peter[/quote]
HAHAHAHAHAHAHAHA, man that's classic.
I'll pick some of those up next time I'm near the RatShack.
Matt
[quote author="dripelectronics"][quote author="peterc"]
[/quote]
thats dirty :oops:[/quote]
No, we WON'T think about it...
[quote author="Kev"]M3 screws and 6mm 8mm or 10mm brass based stand-offs
[/quote]
... or stand-offs of nylon with M3, very practical and also safe if you use two screws, one at each end. M3x 6 screw is fine.
Here's a newbie question:
How do you countersink your standoffs into the bottom of the unit?
I've used a countersink for wood. But what kind of tool do you use to countersink into metal. I imagine you have to be pretty precise to avoid drilling right through the metal.
Any links to tools or parts would be appreciated.
[quote author="kato"]I imagine you have to be pretty precise to avoid drilling right through the metal.[/quote]correct
:grin:
careful use of the end stop on the vertical drill
and then use feel and presure and perhaps a sheet of paper or cardboard under the base plate
I work in aluminuin 99% of the time
NO
a regular drill bit can work and I do use it for a short pre-touch
BUT
it can be very unforgiving into bottom plate
and disaster is never far away
sorry
forgot to say that I have a selection of counter-sink bits just to suit my M3 screws
... and I hate it when the supply changes
cos I have to rework my feel and touch and couter-sink selection
my metal work is always very touchy feely
that's why I'd never make any money trying to be a manufacturer or service provider
and why I work for someone else ... ie the day job
:green:
:shock:
I probably just added to the end of one of my orders to Farnell
or
picked it up over the counter at Jaycar
I know I've got all of Jaycar's and Farnell's stepped drills and the counter-sinks probably were sourced around the same time.
..... :roll:
brand name ... HALL ??
Yeah sorry about the newbie-ness my questions; I have never even heard of M3 type screws before. I assume this refers to a "size" of screw.
I found them at digikey:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=242124&Row=133439&Site=US
