Please forgive the question (I am new here) but what don’t you like about the stock capsule ?Hello
Just purchased a used MXL tube mic. All stock components.
I am planning to change capsule for a new one. Any recomentations?
Maybe 797Audio?
The 960 is a cardioid only mic. Installing a 2 sided (multi-pattern) capsule will not make it multi-pattern.Thanks for the replys, guys.
This mic has only cardioid pattern so I thinks that I must purchase a K47 one.
Anyone tried the WTG capsules? Maybe not as good as the Maiku...
As far as I am aware no one has ever traced the mic circuit. The board looks like a V69.How much tdo you understand circuit design?
Is it the same circuit as the V69?
V69 Mod | Mark-O-Matic
Filter/EQ between stages is what first comes to mind before changing a capsule or caps
If so you might be able to add a LPF between stages and keep the stock capsule.
I have a V69 and I don't understand the design I starter to trace mine and stopped IMO not worth the effort except maybe adding a lowpass filter
It apears to be an anode follower charge amp at about a gain of -1 to a GUESS Schoeps? like circuit output circuit.
I would guess you could remove the tube and go to the input JFET(I would change it to a different JFET if it is a 170 and rebias the JFET)and add a lowpass shelf filter in the circuit.
The input is a big distance from the capsule
I a not going to add any design work in this thread the post is just some things to get people thinking
