saxmonster
- Joined
- Jan 3, 2012
- Messages
- 534
Should I swap it out. The stock one seems very noisy and picks up Gnd Buzzes RF very easily.
What ratio should I look at?
-Scott
-Scott
Enchilada said:
+1I put the Edcor RMX1 in mine and honestly did not notice much of an improvement.
dmp said:+1I put the Edcor RMX1 in mine and honestly did not notice much of an improvement.
I swapped the transformer in my R144 with a transformer from a better sounding ribbon mic. The R144 sounded the same as before.
lt isn't a very good sounding ribbon mic, in my opinion. Needs more than the transformer anyway. Weirdness in the frequency response.
I'm not an expert but ribbon mics are pretty simple. Unless the acoustics of the body and grill were the problem, it would have to be something about the ribbon I think. I'd like to buy some ribbon stock to try replacing it.Do they need a thinner ribbon, or do you think the problem is elsewhere? Seems to me I remember them claiming a 1.8 micron ribbon, but then heard others say that in fact it did not seem to be the case.
Perhaps the ribbon is not even mounted right?
Thanks for the tip - I just ordered a sheet to experiment withI have some 1.8 micron aluminum that I got from the Lebow Company in Goleta, CA. Just under $30 for a piece @ 8" square.
