I found gutshots of the M136 and figured out the resistor values in the oscillator. I then changed C15 to 22pF, R48 to 36k and R49 to 120k in my Fostex 3070, that gave me an oscillator clock running at 350khz in the fostex, but the function of the 3070 wasn't stable at that clock speed. I then reverted back to 33pf for C15, but kept the changes for R48-49, that gave me a 270khz oscillator in the Fostex with all the functions of the compressor/limiter and gate being stable. I will use it some more days, then make the same modification to the other channel. But as it is right now the modified channel works and sounds just fine.
