aspenleaf
New member
Hello,
I'm trying to diagnose a buzz/hum in one channel of a Presonus MP20 mic preamp with Jensen transformers and LT1357 opamps. The noise is only audible when the gain is over 75%, but channel one has the buzz/hum, while channel two doesn't. I have gone over the circuit board looking for broken connections or cold solder joints and found a few, but it did not correct the problem. I checked the ground points on the board for continuity and everything seems to be in order. The buzz/hum happens whether a mic or instrument is connected or not. It also appears at the channel outputs, the mixer output and the headphone output. Engaging the 20db pad doesn't seem to affect the buzz/hum, only the level of hiss.
I couldn't find a schematic anywhere, but I'm hoping one of the more experienced readers here can offer some suggestions on solving this problem.
Thanks in advance.
Thanks in advance.
