Need help figuring out this reverb driver transformer (Gibson e6400)
JW
Portland USA
Here's a scheamatic: http://i142.photobucket.com/albums/r106/capnjuan/gibson%20falcon/GibsonGA19MaestroM216.jpg
It's a Gibson Falcon GA19 RVT The original transformer was open, so I replaced it with an off the shelf fender reverb driver transformer (E 037099) that I bought off ebay.
I haven't been able to locate any information on either of these transformers though. Very frustrating. But I'm thinking it's very likely I put in an incorrect transformer as a replacement.
Problem is the reverb circuit fuzzes out way too early, around 11:00 on the reverb pan dial. I'd like to be able to crank it up even more when I want to.
I've tried swapping the 6C4 tube and I get the same result. The transformer primary is connected directly to the 6C4 plate and the reverb tank measures a low 185 ohm  input impedance.
Can someone recommend the appropriate ratio transformer I should be looking for here? Or even a suitable replacement?
probably a 100:1 like the Fender transformers,
a lot of amps have full reverb as soon as you turn the knob, probably a sales thing,
measure the DCR of the input to the reverb pan,  should be low ohms, other side should be higher, like 276,
maybe mod the makeup stage with a voltage divider, small  caps can be used also to tweak the tone,
I thought the Gibson Pan and Transformer was way different than Fender, but it's been awhile since I worked on one. You might try a Fender pan as a quick fix.
That's a nominal 600r tank.
Fenders run 8r tank.
The get-er-done fix is to insert a stock Fender-like tank, then MARK the change on the chassis so later techs know it is changed.
missed the DCR, sorry,
Mercury has them, (they have everything, but big $$)
http://mercurymagnetics.com/pages/catalog/manufacturers/MM_gibson.htm
