elskardio
Hi guys,
I'm presently working on a Variable high pass filter based on ESP project 155 (http://sound.whsites.net/project155.htm)
I added a switch to create a resonance of +/- 5dB around the cutoff frequency (HPF_Bump).
I also added a switch to change the slope to 6 dB/octave. (HPF_6DB)
I built a prototype and everything works but... if the HPF_BUMP switch is pushed and you push the HPF_6DB switch, it makes a loud noise for a brief moment.
It sounds like the opamp is oscillating for a brief moment. I guess it doesn't like not having any signal at the input while the switch breaks the signal before reconnecting.
Any help on the design would be appreciated.
