codered
http://www.twin-x.com/groupdiy/displayimage.php?album=random&cat=10183&pos=-4596
http://www.twin-x.com/groupdiy/displayimage.php?album=475&pos=1
I have an Electrodyne module 710-L which I want to rack.It has a Reichenbach input tranny which I suppose will sound good. One of my friends had a pair racked and they sounded awesome. Neve modules like the 1073 have a Mic Input,Line Input & Line out .The signal for the mic input goes through the mic amp and then through the line amp and finally output.
In this case L-10 is mic input ,Line input is terminal E and line out is terminal 2. However I am unable to understand where to connect terminal 7 which is the switch output.Also there is 1 (mic-amp output) and B (switch input) .Logic tells me mic-amp output needs to be connected to switch input.Is my understanding correct ?Still confused about 7 though
1.From the block diagram it appears that the output is unbalanced .I have a UTC A-37 which is 50:500 transformer.. would this be too much gain ?
2.Im planning to use the existing ALTEC fader as the attenuator
your help is appreciated
