Nelson Pass B1 Buffer as mic FET circuit.
This circuit uses a constant current source in place of the usual bias resistor to gnd on the FET source, and a voltage divider to feed half the supply to the gate.
Thoughts on why this is seen in few if any microphones? Using well-matched FET pairs it eliminates the usual tedious biasing procedure - or am I missing something?
As a way to bias the capsule's FET, or elsewhere in the circuits?
Some reason they fell out of favor?
Yeah, I looked that up after you mentioned it; here the CCS appears to be on the drain, with the source conventionally biased with a resistor to gnd. And the op amp is doing . . . what?
