Neotek Series 1E schematics?
pirate
Active member
Richmond, Va
Hey guys,
I am looking for schematics for a Neotek Series 1E console. It appears to be in really great condition, but i know once i get under the hood it will really come in handy. Anyone have schematics to share?
I'll let ya know tomorrow, i might have a block diagram....do you want any specific part...ie input modules?
Gyraf has most of the neotek schematics on their page, don't know if it's the 1E though...
http://www.gyraf.dk/schematics/schematics.html
Join the Neotek mailing list.  Someone there will most likely be able to help you out.
http://www.analogbros.com/neotek/listinfo.html
Don
Thanks, Guys!
Most of the information i have found, like on the Gyraf site, is for the Elite or Elan. I had come across that listserv, but wanted to check here first.
Thanks a million!
does anyone have a pin out for the Series 1E with 8 inout assignment?  I want to rack out one but cant find info.
Here's some stuff that you may have seen
https://groupdiy.com/index.php?topic=14520.msg168186#msg168186
And Theater Module schems
From Left to right looking behind the module
Pin 1 Phantom input (+48)
Pin 2 Buss 1 out
Pin 3 Buss 2 out
Pin 4 Buss 3 out
Pin 5 Buss 4 out
Pin 6 Buss 5 out
Pin 7 Buss 6 out
Pin 8 Buss 7 out
Pin 9 Buss 8 out
Pin 10 2Mix out L
Pin 11 2Mix out R
Pin 12
Pin 13
Pin 14 Mic in GND
Pin 15 Mic In Low
Pin 16 Mic in High
Pin 17 GND
Pin 18 Patch return from line in
Pin 19 Channel patch send
Pin 20 Channel patch return
Pin 21 +18v
Pin 22 +18v
Pin 23 -18v
Pin 24 -18v
Pin 25 Echo D
Pin 26 Echo C
Pin 27 Foldback B
Pin 28 Foldback A
Pin 29 Peak Ref Bus.
Pin 30 Unmute Sense buss
Pin 31 Solo Logic
Pin 32 Solo Audio
Pin 33 Peak Ref Bus.(alternate)
Pin 34 GND
Pin 35 Line feed to Submix (unbalanced)
Pin 36 Line In Low
Pin 37 Line In High
Pin 38 Direct Out
Pin 39 Fader Top Send
Pin 40 Fader Wiper Return
    217.8 KB
With regard to the Neotek Mike  Pre. The original front end transistors are no longer available.  2N5087's will work nicely & should still be available from distributors; although they have reached end of life with the major manufacturers. The Opamps are TLO 71's.
Hey guys, sorry to bring up this thread again from 2018. I just bought a Neotek Series 1 16x8 and I’m looking for schematics for it. Are these schematics and pinouts for the Theater version going to be the same for the standard?
