Neumann Gefell M582 DIY PSU
Falk
Good morning, I just wanted to briefly document a solution I tried for two microphones I was given from a friend. He pulled them out of a trashbin at a theater he was working at. I sent the microphones to a complete overhaul to Andreas Stenzel. The mics came back in great shape. Totally recommend his work.
Anyway. I didnt get a power supply with the friends gift and didnt want to spend much on this as I have enough mics in the locker and they were just an add on.
I bought this PSU at Thomann:
https://www.thomann.de/de/the_t.bone_psu_retro_tube_ii.htm
It delivers:
150V/10MA
+6.3V/300MA
Mic needs:
120V/0.7MA
+5.8V/150MA
This PSU matches exactly this schematic:
I changed D5 and D6 to 60V Zeners to have 120V for the EC92.
Then I cut the trace between L7806 and C10 and reconnected it with a 4r resitor.
I used this cable and a NS84 connector to connect the PSU and the microphone.
https://www.thomann.de/de/the_t.bone_xlr_7_pin_cable_10m.htmI disconnected the pin with the variable voltage.
Here is the mic schematic with pinout:
It works great and costs 120€ per channel.
Enjoy your PSU!
Falk
A question I haven't found an answer to regarding this specific PSU : does it use the same transformer as the Apex 460/ T-bone SCT 2000 PSU? Does it have the same 200V and 9.5V secondaries?
