Neumann PsvB schematic/infos request
If it's faulty or damaged, it can be reverse-engineered, and then troubleshot and repaired.
If it needs to be recreated, there's more than one way to skin this cat (ie. a power supply doesn't necessarily need to be 100000% identical to the original's topology or components, in order to provide the same level of performance, or better).
Understood!
I'm looking for schematic to repair my unit and pinout as well
+ some data if there's any about hook up in the console
Single channel and discrete so not similar in that way but still neumann Zero ohm/virtual earth design. I have been told these are the best sounding neumann summing amps, i use the later PSVE type with OA10's i have also used the PSVD and didn't notice much difference between them. I much prefer the discrete units sound to the V475 but i am not saying 475 is bad.
