I have one of these Neumann U473 compressor module that has stopped working
The compressor/limiter function doesn't work anymore, neither does the gain reduction meter
The circuit is still passing a signal and the expander section is working fine that means that the VCA is working, I am very glad that's not the problem as it would have been very hard to find a replacement
I cannot figure out where the fault is, i presume it is somewhere in the detector section, but cannot understand how to trace this part of the circuit, it is rather complex
If someone worked on these units before and can share some suggestions i would really appreciate
original schematics attached
