swordfishtrombones
Member
I have 2 x 2 channel Neve 1272 clones that I bought from Revive Audio about 10 years ago. Right from when I received them, I have had the problem that any of the channels may lose nearly all of it's volume apparently randomly. It can happen to one channel and not the other.
The preamps have a pad switch, and phase switch, and a phantom power switch before the input transformer. There is a DI input that bypasses the input transformer.
Things I have tried:
Returning them to Revive Audio - soon after I bought them I sent them back to Revive Audio - they could not find anything wrong with them.
Bypassing the pad and phase switch - makes no difference
Balanced and unbalanced output connections my interface
Difference interfaces (tried about 4 or 5 over the years)
Something odd I did notice - I gave up on using them as mic preamps as they weren't reliable. I used one unit between a Radial J33 phono preamp and a stereo power amp and it worked flawlessly. The Radial has an output impedance of 600 ohms, whereas most mics I have used with it would be about 150-200 ohms.
I haven't ever been able to deliberately recreate the issue using a test tone from my interface, it has only ever happened when using a mic and recording something. Very frustrating!
I haven't been able to find any 1272 troubleshooting guides, are there any available?
