lassoharp said:
So the pad's impedance should match the source impedance - in this case a mic - not the soundcard's 24K input impedance. If the source impedance is a 600ohm output then your pad should usually be built to match 600 ohms. It may help to think of this situation loosely as - the mics output imp is 'matched' to the soundcard's input imp via bridging condition. The pad's impedance is matching the mic's(or other source) imp via true matching condition - For all the reasons you read in shabteks posts.
Ok, now i understand, i was kind of seeing it the other way arround. :
wkbdgeorge said:
Hubert, What kind of resistors are you using? If they were an inductive type, correct me if im wrong, but wouldnt they affect frequency response? -George
Some 1/2w carbon comp resistors. Is there a big difference with metal film in that application?
Sorry by the way for the ''thread hijacking''.
Here's is a schemo from the rane web site. So input on the right and output on the left. Let say that i want a 600ohm 20 db pad. How do we caculate the right values? I think that it will help me understand!
