Rybow
Picked up a Blackstar series one 45 combo from a pawn shop for $600 last year. Amp sounds awesome, but it had a problem of going microphonic when played loud. A little investigation (smacking it on the top and replacing tubes) revealed the preamp tubes were getting loosened a little from the vibration. Another issue is I’m just too damn old to carry around big heavy combo amps.
I inherited my childhood dresser recently, so that gave me all the raw material I needed. The age of the wood meant mitre joints were going to be difficult. The wood also chips very easily, so I opted for brute force glue and screw butt joints to make it square.
My incredible talent for procrastination means that it is now too cold to lacquer it up. I used aniline dye for the colour, which is very weak & dull without a clear coat. I decided to mount the amp in the new chassis too keep it from getting more messed up than it already has while I wait for spring.
I’ll be moving that cross beam to the bottom back, and installing rails on the sides to support the amp. I’m very undecided on what to do with the front! Perforated steel, etched aluminum, engraved plexi glass or just grill cloth are all on the table. I honestly don’t care if it matches the speaker cabinet. Any other ideas for a unique and striking front for this bad boy?
