New year, new mic...RCA type MI-10002 Uni-Angular Electrostatic (experimental build)
pinchemotherloaf
West Coast, USA
Most likely will sound rough, but I've always wanted to try this drawing anyways! RCA MI-10002 Uni-Angular Electrostatic. Could be a bit harsh, there is no grid or output coupling cap. I used the new cheap u47 case, replaced the saddle with a better one than provided. Modified top plate for tube standoff and added cheap E.H. tube. 500m grid leak. Will probable use an edge terminated single sided capsule. Just fun and games, nothing too serious. Any opinions if this will work?
    174.9 KB
    109.9 KB
    103 KB
Sure, this is a lot like the Altec mics. There’s an output cap, look again.
Hmm, I see 2 caps on the B+ section (ac decoupling) and 2 more, one between ground to capsule and the other between ground to anode. This is a cathode follower so I see the cathode going straight to transformer. Which cap are you thinking is for the output coupling cap? I may have missed something!
Yep, I wasn’t seeing it all on my phone. It’s a DC capable transformer.
I don’t know anything about that transformer but this looks like less than 1mA worst case shorted tube, so well less than that if my calc is remotely correct.
Found two pictures of the M1-10002 A little lower than 1/2 down in the pictures
https://hollywoodsound.com/mic-collection
page 19 https://worldradiohistory.com/Archive-Catalogs/RCA/RCA-Audio-5th-1964.pdf
Have not found any information on the transformer used in the cathode follower circuit. I would guess greater than 4:1
the 150k as the last R in the R C R C going to the plate makes me think the tube is running at lower current because the circuit is powered with 135VDC
1mA would be 150VDC drop
.1mA would be 15VDC drop
etc.
It is a cathode follower with a transformer in the cathode section. I would guess it is a gapped SE type or maybe has 2 or 3 lam interleaving
What do you mean? Do you think the absence of coupling caps is a cause for "harshness"?
Don't know, I'm just used to seeing one in the circuit for either blocking dc or filtering. Not sure why RCA didn't put one there. Maybe they inserted one post transformer. But might still sound sweet, I should remain more optimistic about this build!
The transformer looks to be the most interesting part of the microphone.
Was the RCA 303502 gapped, Si steel lams, interleaved etc.? what was the ratio, 4:1 or10:1 etc.?
Some things to read
https://www.tubecad.com/2005/June/blog0049.htm
https://www.tubecad.com/2005/June/blog0048.htm
https://www.tubecad.com/2012/05/blog0230.htm
Some things to read
Thank you for the info. I haven't found much on the transformer. I used the 3U just as a kludge. I suspect the xformer was a can of some type. Will see how it sounds with the 3U and compensate.
The question remains why an output cap is not used?
The circuit is designed around the transformer, your one (3U) is not a good one for this application.
The transformer also sets the operating point of the tube (bias).
It’s not really a question. It’s a direct feed circuit, while most are parallel feed. Look at preamp circuits, you’ll see both. Being a cathode follower makes it look unusual perhaps, but it’s no different. RCA is more often than not direct feed which has its own advantages.
Another page tells us the MI-10003 is the windscreen, and the MI-10005 is the bit with the transformer and B+ filter elements.
MI-10002 is mic without windscreen, MI-10004 is with.
