I think I'm going to try to build something, which is a bold move for a guy like myself with a history of frustration about audio gear, not to mention my specialized needs.
But it would be a relatively simple project, and I wanted to ask the tribe about a couple of basic points to make sure I am thinking about it correctly before I start to spend money.
The general idea is to have one or two front end mic interface boxes that would give me a -20 db U pad and a phantom switch on each channel, so that I can more easily use my old fixed gain preamps.
I'm thinking I might be able to accomplish this by ordering rack chassis pre punched from Par Metal, and using the JLM Go Between kits, and an Acopian or similar power supply. But JLM also has a 48 v supply.
The questions I had at first are:
1) for vintage tube preamps like Cinema Engineering 102AX and WSW 811 301, do I need to make sure that these preamps aren't seeing phantom power at the inputs ?
2) if yes, does the JLM Go Between kit have blocking resistors that would prevent the phantom power from going back to the preamps ? (Or if not, could they be added in a simple way, like hanging from the XLR connector on the back of the box ? I can solder, but that's about it.)
3) the JLM power supply that I am looking at says it "Runs on mains voltage of 85vac to 265vac without switching." Does that mean it is linear when run off of a 120 vac outlet ? Or do I need to go with something like this ?
http://www.acopian.com/store/productdetail.aspx?q=i481
If this works out, I'd be happy to share the details, might at least save someone else some time in ordering the same chassis for the same type of project.
thanks, Mark
thanks, Mark
