ricardo:
Apologies, I don't mean to oppose your guidance which is sure to be based on more experience that I have with ambisonics.
As I said earlier; this thread is my
first exposure to the concepts of ambisonic recording. I don't know the OP's preamp design except that he shows a picture of a Soundfield product as a reference and plans to use 4 EDEN preamps and wants ganged gain.
I acknowledge your point that using accurate components, and given a well designed preamp you could get the accuracy ambisonic (apparently) needs.
- I don't know what the Eden preamp adds in terms of variability and since the schematic appears to be unpublished, and they come pre-assembled except for certain (all?) gain resistors.
- Without a schematic and component tolerances I don't know how judge what differences there might be between individual assembled Edens.
- Also I know from making 23 step 2dB decades that finding resistors for all the positions in that stack for some values can expensive, and so I would end up with "small sets" that can have variability.
- I don't know what test equipment or components the OP has at his disposal
- OP did state he was on a budget
My recommendation was intended to help the OP, a self proclaimed Newbie, and I suggested a 4 wafer 24 throw Chinese rotary switch with a decade scale of resistors as a ganged gain control (switch not twiddled knobs). I also suggested a multi turn trimmer in series with each wafer to calibrate out any differences of unknown origin between the amps.
I acknowledge that to your point, the gain pot may be un-necessary especially if the builder could control preamp design, construction, and component tolerances.
I can't try it out because I am not building one, OP is. I am not building one, just trying to help out.
If I did build one I would put the gain trimmer onto the design and jumper across it if it was redundant.
Regarding the Soundfield document reference: Yes, you are correct it is on page 8
I am intrigued by the whole Ambisonic technique, in particular the ability to post process virtual mic placement direction after the fact and want to learn more. I was going to look into seeing if I could get or build or cobble together a mic and use equipment I have in place to try the technique (among a zillion other projects).
I am sure the OP welcomes your suggestions, and I will withdraw from this conversation because I really am over my head with ambisonics and the issues that surround them. I meant no offense.
bb
