k brown
Get yourself a now-discontinued AKG Perception 120 (or P120; I've taken them both apart and could see no difference, even though some reviews claim the P120 has an externally polarized capsule), and just drop in this large electret (discovered by kingkorg - $8.50, get 'em while they last). 25mm Large Diaphragm Microphone Cartridge Core Recording Condenser Mic Capsule | eBay
The original capsule is literally the exact same cheap Transound electret SDC in the same, cheap gold-painted plastic ring as the Samson C01. But the mic's electronics are quite fine.
If the capsule mounting post is rotated 90 degrees in it's rubber bushing, the new capsule can be mounted in a simple loop of brass strap. I ran a strip of self-adhesive craft foam around the outside of the capsule for a bit of additional mechanical isolation (the rubber-mounted post doesn't provide much). After assy, I damped the mounting post/brass strap by covering it with 3M Mastic Tape (not shown in photo).
Unlike the BM700/800s, the AKG has a proper dome under the capsule, a heavy, solid body and lo cut and pad switches; unlike the P220, it is transformerless output.
Sounds very,very close to the AKG P220 with kingkorg's capacitor mod; very slightly less bright (but not as quiet):
https://groupdiy.com/threads/akg-perception-p220-to-neumann-u87-5-min-mod-p200-p100-p400-p420.67473/
Also, noticeably smoother than my AT2035 (that could be more due to the AT's tranformer than the capsule or electronics).
For a little more dough (~$20), this big boy (34mm) is even better, and quieter ( I may even like it better than the modded P220):
https://micbooster.com/jli-microphones/266-jli-3412-cardioid-electret-microphone.html
