pucho812
Trying to work out where we are getting noise from when using our studio plates. This has been a problem well before I was working here and now that I am, I am trying to work out all the buzzes and hums. Luckily this is the last of the punch list stuff. For starters our plates are located in their own box in a separate room behind the control room. The box is just a wood frame with drywall around it and a door. It houses our 2 X plates in their own wood frame boxes which sit decoupled from the floo. They are on a different electrical circuit and have about 30-35 feet or so of balanced snake cable between the patch bay in the control room . One has emt solid state electronics, the other has martin sound electronics. The plate with EMT electronics has a light hum, and it can be heard if I crank up the monitors to full. I assume this is normal for a plate that old that has seen little servicing. nothing that can't be addressed in time.
The Martin sound electronics have large amount of hum. I have swapped power around with marginal success, meaning I ran a power extension cord from the control room power circuits and connected to the plate with a reduction in buzz but still low frequency hum. I have tried running audio cables directly from the control room to the plates and still had issues. I have confirmed the patchy connections are solid and working as they should.
The Martin sound plate electronics had recently been serviced and given a clean bill of health by the manufacture.
So as I read and comb over Bill Whitlock, does anyone have any ideas of things I can try out?
