schmidlin said:
Can you measure the DC resistance on a choke and use that measurement to accurately calculate current draw over it?
Thanks in advance.
Are you asking - can it(DCR) be treated as a resistor - measure a drop and then calculate current? If it's a mystery choke I would do a test jig circuit with some very low safe draw, say 3 to 5ma. If choke DCR measures 520r then A/B it with a 520r resistor in same position and check drop difference. That would seem to give you a real picture of the in circuit IR drop, current and dissipation numbers.
EDIT - If you're confident it's at least up to doing say 20ma - then test at low and then a higher current draw and see if observed drop changes.
