NOS Haufe RK282 – info needed
Claudio
Hello everyone,
I was given a few ‘new old stock’ Haufe RK282 transformers, I suppose from the 80s or older. However, I can’t seem to find any info or datasheet for this model. Can anyone help me out?
Claudio
Wow, that was fast. Thanks a lot!
I don’t need any translation, I’m German, too.  :)
So have you used this transformer in one of your projects? What was it? How did you use it?
Claudio
No, I have not used this model yet, but similar ones. Relatively difficult to drive for a tube guy. You can also use them as input transformers. Silent Arts Volker has a few projects where similar transformers are used....Grüße  ;)
Yes, I first came across the Haufe transformers when I built Volker’s modules. I should contact him. :)
Claudio
It's a opamp output transformer. Or some other circuit with plenty of NFB and similarly low output impedance.
Hey Volker! :)
Sorry to ask, but what is an opamp output transformer? Do you mean a transformer that follows an opamp in the signal chain?
And what does NFB mean?
You need a relatively large amount of current to drive these transformers, low impedance. This is achieved with potent opamps and/or transistor buffers. These transformers do not fit well to tube circuits.
NFB= negative feedback to lower the impedance.
For anyone who needs it, here’s the official datasheet that Haufe sent me.
  • Haufe_RK282_Datenblatt.pdf
