Now that's some coax
They were wiring up cell phone equipment in a building I used work before , a very similar air cored co-ax was used , looks difficult to work with but they were able put in a wide bend radius so it could turn corners and avoid obstacles etc .
I worked in FM broadcast and always enjoyed working at the transmitter sites since they were far, far away from the office, out in the country and in clean air.
I didn't listen to the audio of the clip but seeing that carbonized spacer made me feel lucky I never had to deal with a transmission line or antenna flash-over burn. Keeping the line under slight positive pressure with either dry air or nitrogen is a must to prevent moisture ingress. Once you get a flash-over a tower crew has to come out, repair the flash-over point and swab the line and spacers below it. You're either off the air, running on an alternative site, or patched into a broadband auxiliary antenna and transmission line shared with your co-located FM neighbors.
Reflected power is the Canary in your coal mine and the thing you watch closely during icing.
Joe and Jeff Geerling explore Crestwood Master Tower's 10 FM 1MW (ERP) combined antenna site serving Saint Louis, Missouri.
Part 2:
