This is a finished product that started as a DIY project here at GDIY.
As I understand there are many users here whom contributed to it in a direct, or indirect way.
Disclaimer. I received this mic from @Scrappersa as appreciation for my help. He didn't ask me to do any kind of review, or post anything. He did agree with MY suggestion to post the findings.
I will do my best to stay unbiassed, but i have to say it's not easy. This thing is nicest looking, and most beautifully manufactured piece of gear i've ever touched, and probably even seen. No wonder, @Scrappersa is a jeweler, and this thing is a jewel for sure. The only thing missing is jewelry price. It is also a premium example of my stands on innovation, manufacturing, how things should be taken at least one step forward.
It has a modified Debenhalm capsule, and uses km84 circuit from what I understand. Sorry, there will be no internal pictures, I don't think I'll ever disassemble this mic. Start to finish made in USA. Not aware of any existing mic with this combo.
Once I saw the development images on Instagram, I was a bit uncertain about how the headbasket will influence the sound, there's a lot going on there. Surprisingly, the headbasket is pretty transparent, but it does add some character to the sound. Nothing crazy though, no crazy resonances. No idea if this was the intention, but as the grille is detachable, and swappable, different variations will impact the sound. So you don't get just the look variation, but also you get to change the sound character. The mic can also be used without the grille.
He also sent me a blank capsule without a diaphragm. I'll post the images of it later. I'll skin the capsule at some point and take a measurement of the capsule itself, outside the body. I'm not even going to try to remove the one that's inside the mic.
The mic has huge low end, and gentle HF boost. I'd say the low end is similar to a good CK12 capsule, but at the high end you get a lot of k47 characteristics pattern wise as they share similar backplate design. HF response is unique, and not similar to any capsule i am aware of. Kinda like a k67 in a well tuned circuit. The response is somewhat wavier than my usual measurements, but this is because i usually measure the capsules outside the body. This is perfectly normal. This is the response of the mic in it's stock form, with the grille removed it gets slightly different, but not much. Great 180 degree rejection even at high frequencies.
The green curve is without the grille.
I almost forgot to mention, it sounds marvelous, and huge even at distance.
There are many images out there, I think video does a better job.
