q2audio
I recently modded four Oktava 319 mic's per the recent Scott Dorsey article. All went well until I managed to slightly crease a capsule while removing a baffle (I'm not good around fragile things... so why was I doing this, I ask myself...). While I don't hear any negative effects of the visible "damage" to the capsule, I still feel the need to at least locate a replacement in the event I want to replace it. Does anyone here have a source for these? The mics were CHEAP from GC, so my best bet may just be to get another one from them... This whole damage thing kind of sucks because I matched the mics into pairs quite well according to the graphs that came with them.
I found that a small ring of foam around the base of the capsule (covering the white plastic mounting base) seemed to take some weirdness out of the mic. Has anyone else tried to treat this area? What did you use?
As for the body resonance, it appears to be the PCB resonating rather than the body or grille. I removed the guts from a 319 and reassembled the grille to the body and tapped it - quite dead sounding. So the silicone added to the body hopefully will support the PCB and keep it still. I found that "GE Silicone II" does not contain any acids (vinegar) and won't hurt PCB's or components and it cheap!
Thanks for any pointers towards the capsule.
Tim
Tim
