Old tube unit
Zander
Belgium
Does somebody has an idea about this unit?
If so is it worth restoring?
Zander
    1.6 MB
It looks like an old PA amplifier with two mic and one gramophone inputs. All inputs probably high impedance. Might make a nice mono block - performance will be determined mostly by the output transformer. These can sound surprisingly good. I had an old RCA on in for restoration a few years back. Once I got it working I played some music through it and I really liked the sound. I then checked the frequency response and it was rubbish - but it still sounded pleasant.
Looks like a guitar amp to me. (Ian is correct about the original purpose, but who needs a 2-in 12 Watt PA today?)
Smoke-test (outdoors on dry board with long cord). Fix the failed bits. Play. It should handle guitar "fine", and with a tone somewhat different from a Fender or Marshall or Epi tube amp.
That assumes it has 4/8/15 Ohm output taps. Some old PA amps had only 70V, 25V, or even 500 Ohm outputs. If you have 25V with a CT (12.5V one side), that's an OK fit for 10-14 Watts at 8 or 16 Ohms; otherwise it is awkward.
Thans for the replies.
It world reasonable for as a guitar amp. We tried recording through it but it's useless because of the hum. It does have a clean sound for being so old...
Zander
"Fix the failed bits. "
At that age, most of the power filter caps are weak or dead.
Yes, it did hum when new, but probably a lot more today.
